Default report quit populating
For some reason, the default report quit populating while running a program or at all for that matter.
I have the system set for the default report to run in the background and only look at it when needed but, when I select the icon at top, all that opens is a white window with no data.
Tried restarting everything to no avail.
Calypso version 6.8.12.
I've been running this version for at least 6 months and don't recall having this happen.
Seems like this has been brought up before ?
Probably something simple I haven't thought of.
Any ideas why it quit?
https://qualityforum.zeiss.com/topic/13756-default-report-quit-populating/
I just did a test. I'm running Calypso Version 6.8 (13.06.2019). # I need to upgrade soon
Looks like mine doesn't populate until the end of the run either. I unchecked 'clear existing results' and ran the program while taking a screen shot of my default printout. Once the program was over, the default printout then populated with the data.
I can't remember is this just starting happening or not.
Thanks Chad, I guess we replied at the same time.
HOWEVER, I just checked it again after unchecking "halt" and the next time I ran the "halt" was checked again.
Not sure why it's going back to "halt" each time.
I've got other non-CMM stuff to work on so, won't be able to get back on and figure it out for a while, probably next week.
Hopefully somebody else figures it out before then.
