[De...] Posted January 5, 2021 Share Posted January 5, 2021 Having an issue with Calypso 2019 with the simulation graphics. The probe and the quill are in the right spot, but the head appears to be shifted and not connected to the quill. See attached pic. Is this a setting or configuration that I'm missing? Link to comment Share on other sites More sharing options...
[Ri...] Posted January 5, 2021 Share Posted January 5, 2021 You need to apply the proper offsets. Link to comment Share on other sites More sharing options...
[De...] Posted January 5, 2021 Author Share Posted January 5, 2021 Those offsets are pretty close to the ones I have. The only difference is I had 191.6 for Z. Oddly enough, I had these settings in Calypso 2017 and the graphics look normal, but when I transferred to 2019 with the same settings, that's when the quill and head look detached. I suppose that I could play with the Z value, but I didn't think that it is something that I should mess with. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 5, 2021 Share Posted January 5, 2021 Hmm. Try reimporting the SSC file, and see if that corrects it. Link to comment Share on other sites More sharing options...
[De...] Posted January 5, 2021 Author Share Posted January 5, 2021 I re-imported the entire config folder and it still looks like that. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 5, 2021 Share Posted January 5, 2021 You might have a corrupt configuration then. Create a new machine tab, with the correct offsets, and see what kind of results you get. Link to comment Share on other sites More sharing options...
[De...] Posted January 6, 2021 Author Share Posted January 6, 2021 How do I create a new machine tab? Link to comment Share on other sites More sharing options...
