road map with measured / nominal values
Is there a way to develop a road map while executing the layout – Once the machine measures the features, the graphic view can display the measurements with nominal and deviation values?
Shabu is right. If you activate Default Printout under Resources > Define Report (formerly Define Report), click the Default Report (formerly Default Printout) tab. Un-tick the Background checkbox. This will provide live output of the results when you click on the Show default printout icon (1st icon to the left of the Run icon)
With Background ticked, you can still get results but it will only be a snap shot of the current data. You have to close and re-open the report to get more results.
You can go to CAD-Evaluation-Characteristics, turn on display banners, nominal and deviation. Get that set up the way you want it and then next to save view, you can create a CAD presentation.
