Racking Issue
I have an articulating head on a Contura G2 CMM. Not sure how this got changed, but when I change probes to another certain one, and after it changes, instead of going to -Z(A0,B0) position as it always has and how I want it to, it swings to +X(A0,B90). How do I change this setting so it doesn't rotate coming out of the rack?
Thanks
Under the CMM tab go to Stylus System. Calypso will remember the last stylus position before you close this tab. The next time you pick up that stylus system it will automatically move to the last position it was in before the tab was closed. I always make sure the probe is in the down position before closing the tab.
