Startup error
It looks like you might have something corrupted. Is this on a machine or an offline seat?
If it's just an offline seat, you could try going to C:\Users\Public\Documents\Zeiss\CALYPSO\ and renaming the config folder to config.bak
Try to open Calypso again, and see if it loads properly this time.
If that doesn't help, you might have to uninstall and then reinstall Calypso.
https://qualityforum.zeiss.com/topic/13850-startup-error/#findComment-71498
Thanks for the response. It is an offline seat and I tried what you suggested. This time when I opened calypso it seems to have created a new config folder, now I have the new "config" folder and a "config.bak" also calypso lost all of my stylus system and settings. It still gave me an error when I tried to connect to create CMM connection.
https://qualityforum.zeiss.com/topic/13850-startup-error/#findComment-71500
