[Fl...] Posted December 14, 2020 Share Posted December 14, 2020 I have a questions because Below is the same curve profile reported with Bilateral one result, Bilateral two results, and Curve Form. What is correct to determine the value of the Line profile (see pictures) : 1: Profile Bilateral One Result – Takes the point furthest from nominal and doubles the result. 2: Profile Bilateral Two Results – Reports the minimum and maximum points along the curve 3:Curve Form – This characteristic reports the delta between the min/max points of a curve, regardless of the position of the min or max point within the tolerance.1.PNG Link to comment Share on other sites More sharing options...
[Is...] Posted December 14, 2020 Share Posted December 14, 2020 Profile Bilateral One Result ,, but ask to the designer what he wants anyway.. Link to comment Share on other sites More sharing options...
[Fl...] Posted December 14, 2020 Author Share Posted December 14, 2020 I understand BUT: Profile Bilateral One Result – Takes the point furthest from nominal and doubles the result Example :I have the Min (- 0.0164) point and MAX point ( 0.0063) : Result is 0.0164 x 2 = = 0.0328 for Profile Bilateral One Result For Curve Form Result is 0.0228. (Min + Max = Result --- 0.0164 + 0.0063 = 0.0228) The curve form not is the Min + Max??? Thanks Link to comment Share on other sites More sharing options...
[Is...] Posted December 14, 2020 Share Posted December 14, 2020 You are right in all your interpretations. However, form and profile of a surface (GD&T) are not the same.. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 14, 2020 Share Posted December 14, 2020 Profile Bilateral One Results - It can be interpreted as taking the largest deviation from nominal and doubling the results. Profile Bilateral Two Results - Shows the maximum and minimum deviation results from nominal. Would need to double the largest deviation to get the Profile result. Curve Form - Before PiWeb Reporting, this was the only way to form plot the Profile results. Unfortunately it requires you to setup alignments/evaluations (like best fits if needed) to have it show the correct results that make a Line Profile results. The form plot itself will show you the maximum and minimum deviation results from nominal. Would need to double the largest deviation to get the Profile result. The result that you get on the Printout is the range of the maximum to minimum deviation, it is not the Profile result. Link to comment Share on other sites More sharing options...
[Fl...] Posted December 15, 2020 Author Share Posted December 15, 2020 Thanks for answer. I conclusion the correct measurement is with Profile Bilateral One Results? Link to comment Share on other sites More sharing options...
