Nivigator - Offline
My offline station has the Navigator license enabled, however I have noticed that in probe qualification the option Dyn- Tensor is not available, also when I execute the PCM command cmmCanUseNavigator() the result is false..
My CMM configuration is PRISMO with Vast Gold..
Is there something else to activate to enable Navigator in an offline station?
I don't have the Navigator option, but generally Planner is somewhat different from the CNC version when it comes to probe-related stuff. I often need the function "geometry re-qualification" in my qualification programs, but it's not available on a Planner seat (ghosted). Support told me that this is intentional behavior because there's no real qualification data behind simulated probes. Maybe the same is true for the Navigator functions.
My personal opinion is that a simulation which isn't able to simulate correctly, is of limited use.
I wonder if is the same issue with Vast Performance and flyscan,
I don’t remember well but I think even installing a CNC license with navigator in my laptop the Dyn-ensor option was not enabled.
Is it maybe related to the caa files? (square, guideway & Y)
