[Ca...] Posted December 4, 2020 Share Posted December 4, 2020 Hello my Calypso Friends, I have another small problem, perhaps one of you has an idea how to fix it. I want to work with PCM or more specific with the attribut of Space Axis?! Im aware about that its possible to modify Space Axis in Para File .. (-3 = -Z ..... -2 = -Y ..... -1 = -X and the same for Positiv Values. So, i try to explain what im doing. I created a 2D Line which and from this line i want to Copy (Mirrior...) the Space Axis with an Attribute.. For example If i want to take the X Value i use the Formula "getNominal("2DLN_1").x" with this i can get exactly the same attribute on the other 2DLine.. This works for everything, even of Radii, Angels ... but i was not able to find the Attribut to copy the Space Axis, first i tried "getNominal("2DLN_1").axis" which doesnt really work hehe. So, hopfully one of you tried this already and can hook me up with this Attribute. 🙂 Thanks In Advance, Regards Link to comment https://qualityforum.zeiss.com/topic/13924-work-with-pcm-and-space-axis/ Share on other sites More sharing options...
[Kl...] Posted December 4, 2020 Share Posted December 4, 2020 Hallo Carsten, getActual("2d-Gerade1").plcn bzw getNominal("2d-Gerade1").plcn Mir ist jedoch nicht klar, wo Du den Eintrag verwenden möchtest. Link to comment https://qualityforum.zeiss.com/topic/13924-work-with-pcm-and-space-axis/#findComment-72122 Share on other sites More sharing options...
[Ca...] Posted December 9, 2020 Author Share Posted December 9, 2020 Hallo, Super, hat geklappt 🙂 Hab den ".plcn" in keiner Liste gefunden die ich hatte hehe. 🙂 Ich habe ein Programm mit Haufenweise Kontur, da die CAD CAM Schnittstelle noch nicht fertig ist werden diese Aktuell Manuell extrahiert und habe dann einfach eine PCM Verlinkung auf die einzelnen Eingaben gesetzt, nur für die Space Axis hatte ich keinen 🙂 Vielen Dank. Link to comment https://qualityforum.zeiss.com/topic/13924-work-with-pcm-and-space-axis/#findComment-72124 Share on other sites More sharing options...
