Where is that button ??
It's been a little while since I tried this, I forgot where it is. I need put a formula in a feature location that needs to know the probe radius, but I can't seem to find it again. The item I found does not look as I remember it, and it keeps giving me errors when I select it, something about missing brackets. Can someone point me back to the correct item to pull the current probe's radius into a formula?
That works for me, Thanks. One little bug in there however is that while the program is based on inches, Calypso still outputs the result on that command in the metric measure. The program then uses that number as if it where in inches, making the result for a 3mm ruby makes the software move 1.5 inches. Just had to add "/25.4"
I think that you might have a bug because it shouldn't do that.
I just tested it, and it works correctly on my system.
Make sure that you are on the most current service pack for the version of Calypso that you are running.
Opps, I guess I am a little behind on getting the upgrades installed. I am still at 6.2. Anybody know how far I can jump forward in one step? I am pretty sure our license is up to date.
If you don't want to jump versions, just get the latest service pack for 6.2.
I wouldn't see any issues with going to 6.8 or 7.0. The good thing is that you can have multiple versions installed at the same time. I don't ever uninstall old versions incase there is an issue with the newer it will allow me to easily go back.
