True Position of a rectangular slot
Hello all, I'm in the middle of programming this part and I've run into an issue.
Datum -E- is defined as the cutout distance, but for me to define it, I used a symmetry of the two walls.
However, when I plug in my information to the TP dialogue box, there's only an X nominal, and there's no box for the MMC. Can someone explain why I'm running into this issue and how to possibly remedy the situation? 2084_4b94ee9fb811345c8248246bf9deddeb.png
Thanks,
Zach
It looks to me like you have your feature defined as a symmetry construction, when what you want is a symmetry plane feature (Features > Special geometries > Symmetry plane). That will let you apply your material condition modifier.
Thank you! This is exactly what I was looking for!
Thank you for your response as well!
