[Za...] Posted December 7, 2020 Share Posted December 7, 2020 Hello all, I'm in the middle of programming this part and I've run into an issue. Datum -E- is defined as the cutout distance, but for me to define it, I used a symmetry of the two walls. However, when I plug in my information to the TP dialogue box, there's only an X nominal, and there's no box for the MMC. Can someone explain why I'm running into this issue and how to possibly remedy the situation? Thanks, Zach Link to comment https://qualityforum.zeiss.com/topic/13932-true-position-of-a-rectangular-slot/ Share on other sites More sharing options...
[Th...] Posted December 8, 2020 Share Posted December 8, 2020 It looks to me like you have your feature defined as a symmetry construction, when what you want is a symmetry plane feature (Features > Special geometries > Symmetry plane). That will let you apply your material condition modifier. Link to comment https://qualityforum.zeiss.com/topic/13932-true-position-of-a-rectangular-slot/#findComment-72164 Share on other sites More sharing options...
[Ün...] Posted December 8, 2020 Share Posted December 8, 2020 Hello, You can check the attached file about adding MMC to slot size. Link to comment https://qualityforum.zeiss.com/topic/13932-true-position-of-a-rectangular-slot/#findComment-72166 Share on other sites More sharing options...
[Za...] Posted December 8, 2020 Author Share Posted December 8, 2020 Please sign in to view this quote. Thank you! This is exactly what I was looking for! Please sign in to view this quote. Thank you for your response as well! Link to comment https://qualityforum.zeiss.com/topic/13932-true-position-of-a-rectangular-slot/#findComment-72168 Share on other sites More sharing options...
