[Je...] Posted December 1, 2020 Share Posted December 1, 2020 Hello. How would you set up a characteristic(s) and graphics in Calypso, if you were assigned the following task? 1. Compare scanned points captured on a tactile probe to the nominals in a CAD model and highlight deviations above a specific limit. See the attached image from a competitor's software for reference. The end result does not have to contain the density of data that this image contains, as it was captured by a laser-line non-contact scanner. Also, feel free to point me to previous posts, if available. Thanks! Jeff Frodermann CMM Programmer Windings, Inc. New Ulm, MN 56073 Link to comment Share on other sites More sharing options...
[35...] Posted December 1, 2020 Share Posted December 1, 2020 You can use freeform to scan across multiple surfaces with a set density. Recall feature points into a Point Set / Point cloud. You can then create graphics as characteristics. In the characteristics, set the setting to 'CAD Deviation Analysis' instead of a static image. You can then use the CAD Deviation Analysis object in PiWeb to view your data. You can also use CAD > Cad Evaluation and use the Banners to make a static image. Couple different ways. Link to comment Share on other sites More sharing options...
[Ja...] Posted December 4, 2020 Share Posted December 4, 2020 Please sign in to view this quote. Is CAD Deviation Analysis possible with out free form? Link to comment Share on other sites More sharing options...
[Ri...] Posted December 4, 2020 Share Posted December 4, 2020 Please sign in to view this quote. If you use the Point Cloud option there is no need for Free-Form. Link to comment Share on other sites More sharing options...
[35...] Posted December 4, 2020 Share Posted December 4, 2020 Please sign in to view this quote. Perfect. To be honest, I have the most basic of knowledge with collecting data within the actual Point Set object! Link to comment Share on other sites More sharing options...
[Ri...] Posted December 4, 2020 Share Posted December 4, 2020 I mistyped. If you use the Point Cloud option. Point Set requires Free-Form unless you convert the points over to Space Point. Link to comment Share on other sites More sharing options...
[Er...] Posted December 4, 2020 Share Posted December 4, 2020 Please sign in to view this quote. Laura, I cannot seem to find where your change the setting to 'CAD Deviation Analysis'. Can you explain a bit more please? Link to comment Share on other sites More sharing options...
