Startup Calypso
I am having trouble opening Calypso. I last use to load/save environment under file...it froze. I had to use task manger to shut it down and now I can get it to open Calypso. The screen shot is what I'm seeing ….I have never see this before. Any advice. My software agreement contract expired!!!!!!
With the risk to be wrong: but maybe the RAM doesn’t have more space available:
(I would check if the Workstation achieve the Minimum requirements and secondly I would set a new CMM configuration.)
Israel is correct, but your physical amound of RAM doesnt have anything to do with this, the applications memory allocation is 2 147 483 648B (2048MB in binary), and you sir are leaking like wikileaks... 😃
Normal usage is between ~300-400MB.
If you know how, you could try to force a garbage collection. Otherwise, call Zeiss, or repare your Calypso installation.
  • 2 weeks later...
