[Ry...] Posted December 2, 2020 Share Posted December 2, 2020 Does Calypso save old reports? If so how do i find them? For example the attached PDF shows incremental part number 26, is there a way to find #1 - #25 sample.pdfFetching info... Link to comment Share on other sites More sharing options...
[Ja...] Posted December 2, 2020 Share Posted December 2, 2020 Go to Extras-settings-environment-paths. The "default paths for results files" is the default location. Link to comment Share on other sites More sharing options...
[Ow...] Posted December 2, 2020 Share Posted December 2, 2020 It depends on if you have it set to save the reports and what type of report you're using (custom or pi-web, etc,) and what version of calypso you're running. If the program or global system is set to save them they are usually found here.: Calypso version 5.4 and older. - C:\Zeiss\Calypso\home\om\workarea\results. - C:\Program Files\Zeiss\Calypso\home\om\workarea\results. - C:\Program Files(x86)\Zeiss\Calypso\home\om\workarea\results Calypso version 5.6 or newer?: C:\Users\Public\Public Documents\Zeiss\CALYPSO\workarea\results Several ways to save the report in the program if it's not saving them but, generally with the custom report - is go to resources and select "results to file" and turn on the PDF report. Link to comment Share on other sites More sharing options...
