VWNT.EXE Has Stopped Working
I have reached out in the past about this but did not receive an answer so will try again.
Calypso 2019 version 6.8.1201 installed on an ACCURA2, Contura G2 plus a Planner seat.
All three will indiscriminately throw out the VWNT.EXE Has stopped working and Calypso will shut down, even in the middle of a run. So far nothing has crashed or broke because of this. The last time this happened I was able to run a debugging program which said there was a problem with the Microsoft SQL Server 2014 (64bit) and it needs to be re-installed.
Great! Where do I find this? Could not locate it in the Calypso install package. Any ideas? HELP
Greg
I found it in the release notes on page 149 (Section 3-23).
"The required software can be found on the CALYPSO 2019 data carrier under CALYPSO -> ISSetupPrerequisites ->
Microsoft SQL Server2014 Express SP1 (ZEISS SDCO)
I tried finding it myself and i believe it once had its home in ther service packs but i couldn't find it. However i did find the SQL downloads on Microsoft.com
https://www.microsoft.com/en-US/downloa ... x?id=42299
Thank you Andre. Found it in the following ZEISS CALYPSO 2019 full version (6.8)\CALYPSO\ISSetupPrerequisites\{FDE58EAF}. Executed the SQLServer2014Upgrade file and so far so good. For now I am working with our Planner package so if there is a crash it will not effect our CMM's
Again thank you
Greg
  • 5 months later...
Hello, Gregory
I started getting the same error at intervals. Happened twice yesterday
Did you get the error again after running the SQL Server 2014 Upgrade file 2500_17a042d9911c635a3a83d18cbedbd2b7.png
I have not received the error message since I installed SQL Server 2014 Upgrade file.
Interestingly our Calypso 2019 runs smoother since the Server Upgrade.
Greg Kozera
