[Mi...] Posted November 23, 2020 Share Posted November 23, 2020 Riddle me this batman... Been running the same program out of Auto Run for 4yrs. Runs at least 3x month. Today I try to run the same program and it hits the Left limit switch (X axis). Its never done this. I know I am close to the limit for the machine, but it has ran this way for years until today.... Can you adjust the limits in the X ? And yes I have the fixture set up in the same place and I have also shut drives off and re homed the machine.... Thoughts?? Ideas ??? Link to comment Share on other sites More sharing options...
[Ia...] Posted November 23, 2020 Share Posted November 23, 2020 Do you use any X clearance planes? Link to comment Share on other sites More sharing options...
[Mi...] Posted November 23, 2020 Author Share Posted November 23, 2020 CP are good. I mean the actual head stops short in the X from what it has in the past 3 yrs of running this program. Im racking my head looking at it and cant figure out why today its different from last wed.... Link to comment Share on other sites More sharing options...
[Pe...] Posted November 23, 2020 Share Posted November 23, 2020 Just throwing out ideas - has the stylus configuration been altered at all recently? For instance, if someone replaced an X+ probe with a new one that is a little longer, that would force the head to go further left to clear the CP. Link to comment Share on other sites More sharing options...
[Br...] Posted November 23, 2020 Share Posted November 23, 2020 I've had a similar issue on a Prismo CMM . Have you tried turning off the the controller to force the CMM to Re-Home? This has always worked for me. Link to comment Share on other sites More sharing options...
[SH...] Posted November 23, 2020 Share Posted November 23, 2020 Please sign in to view this quote. For Re-homing you can use the short cut,no need to turn off the controller. Shift+Return+ F12 for C99 controller F11 for old controller. I don't think homeing the machine solve the issue. Link to comment Share on other sites More sharing options...
[Mi...] Posted November 23, 2020 Author Share Posted November 23, 2020 Peter... No. Its a straight down Disc probe. I even checked to see if the OD of the disc got changed but all is ok Brad.. Tried that first thing just to see but same thing Link to comment Share on other sites More sharing options...
