Avoiding Freeform Surface Point Set Collisions
Hello all!
Is there a way to avoid collisions whilst scanning freeform surfaces using Point Set? As you can see in the image attached, there are areas that I'd wish to avoid measuring, however with Point Set it wants to plough straight through to the next point in the set without moving away from the part.
I've tried adding a Clearance height before the collision will occur, however this ends up after the Point Set. Any simple resolutions to this issue? The customer is hounding us at the moment to get it measured and out of the door.
Cheers guys! 😃
