[Lo...] Posted November 16, 2020 Share Posted November 16, 2020 Hello everyone, I have a CAD model loaded into Calypso and I have taken the characteristics I need. But when I go and run the program it errors and I get a message saying Calypso can't compute alignment. What am I missing? Link to comment Share on other sites More sharing options...
[Cl...] Posted November 16, 2020 Share Posted November 16, 2020 Describe the alignment, or add a screen shot. Link to comment Share on other sites More sharing options...
[Lo...] Posted November 16, 2020 Author Share Posted November 16, 2020 Here is a screen shot of the part.Capture.PNG Link to comment Share on other sites More sharing options...
[Mi...] Posted November 16, 2020 Share Posted November 16, 2020 Can you describe what features you tried already? You should be able to use the top surface as your z origin, and the OD or ID as x- and y-origin. Then I'd try either the top surface as spatial rotation (z-axis) and some feature on the horizontal arm (the hole, maybe? or a circle on the OD) as planar rotation, or the horizontal OD cylinder as spatial (x-axis this time) and the top surface as planar. I'm not sure which would be the most stable. Link to comment Share on other sites More sharing options...
[Lo...] Posted November 16, 2020 Author Share Posted November 16, 2020 Spacial Z+ is the flat surface highlighted in dark blueish grey Planar +X is the flat surface of I.D to the far left X and Y origin is the cylinder highlighted in purple Z origin is the flat surface highlighted in dark blueish grey Link to comment Share on other sites More sharing options...
[Cl...] Posted November 16, 2020 Share Posted November 16, 2020 I'd use the ID cylinder on the left for my X+ planar. Link to comment Share on other sites More sharing options...
[Mi...] Posted November 16, 2020 Share Posted November 16, 2020 Please sign in to view this quote. Hmm, it sounds like it should work. You're measuring the planar rotation feature as a plane, not just a single touch point or something like that, right? Would it be possible to replace that feature with an ID circle inside the horizontal section? Link to comment Share on other sites More sharing options...
[Ma...] Posted November 16, 2020 Share Posted November 16, 2020 Try using 3d line from centers of circles for planar instead of one circle. Link to comment Share on other sites More sharing options...
[Da...] Posted November 16, 2020 Share Posted November 16, 2020 You said that the flat surface on the far left was your X+ planar, it should be X-. This feature is what is causing your problem. Change it to X- and it should work. Link to comment Share on other sites More sharing options...
[De...] Posted November 18, 2020 Share Posted November 18, 2020 That part looks familiar to a degree. I work at a place that made medical components for other people, and that looks like the head of a dental tool. Don't remember the company or the name of the tool anymore. Link to comment Share on other sites More sharing options...
