[ca...] Posted September 26, 2022 Share Posted September 26, 2022 Hello everyone, I would like to create a dialog window in which text messages shown dynamically changing with respect to a parameter defined in a script(by adding corresponding integer to the text message). Is it possible to change and control the dialog window messages or header dynamically? Many thanks, Canset Link to comment Share on other sites More sharing options...
[Se...] Posted September 27, 2022 Share Posted September 27, 2022 Hi Canset, You can create the dialog, adapt the label text and then show the dialog. Something like: DIALOG=gom.script.sys.create_user_defined_dialog (...) DIALOG.label_1.text = "desired text" DIALOG.title = "my title" RESULT=gom.script.sys.show_user_defined_dialog (dialog=DIALOG) label_1 is the object name: Hope this helps, Sergio Link to comment Share on other sites More sharing options...
[ca...] Posted September 28, 2022 Author Share Posted September 28, 2022 Hi Sergio, Thanks for the quick response. Is it also possible to do this for continuous text ? I have a specific format and color for the text and i want to keep it when changing the parameter on dialog. Many thanks, Canset Link to comment Share on other sites More sharing options...
[Se...] Posted September 28, 2022 Share Posted September 28, 2022 Hi Canset, Maybe using a "Continuous text" widget? "text" field has html format, and can be also adapted: DIALOG.custom_text.text = "<html><p><span style=\"font-weight:600;\">Bold </span><span style=\"font-style:italic;\">cursive </span><span style=\"color:#ff0000;\">red</span></p></html>" Link to comment Share on other sites More sharing options...
