[Ja...] Posted November 16, 2020 Share Posted November 16, 2020 I have a part with cam surface and i have a point set that needs to be probed. However the distances given are radial distance and angle increments ( cylindrical co-ordinates instead of cartesian co-ordinates). How do I go about defining these points easily and fast? Any suggestions? What I can try: Create secondary alignment and use it to define a point cartesian co-ordinate and then change it to base alignment. Rotate the secondary alignment and repeat process. Seems like a time consuming process to do it for all points. Link to comment https://qualityforum.zeiss.com/topic/14102-defining-points-using-cylindrical-co-ordinates/ Share on other sites More sharing options...
[Cl...] Posted November 16, 2020 Share Posted November 16, 2020 The only thing that I can think of would be to use space points, if you know the nominal coordinates and vectors? Just create them nominally. Link to comment https://qualityforum.zeiss.com/topic/14102-defining-points-using-cylindrical-co-ordinates/#findComment-73282 Share on other sites More sharing options...
[Sh...] Posted November 16, 2020 Share Posted November 16, 2020 You can change the way Calypso displays the coordinates by going to Resources > Features representation. Select the points you are trying to modify, then open the Features representation window and set mode to "modify" At this point you can change the tick from "Cart." to "Cyl.". This should allow you to view your points with Radius/Angle/Height instead of X/Y/Z. Link to comment https://qualityforum.zeiss.com/topic/14102-defining-points-using-cylindrical-co-ordinates/#findComment-73284 Share on other sites More sharing options...
[Ja...] Posted November 17, 2020 Author Share Posted November 17, 2020 Please sign in to view this quote. Thank you Shawn, that works! Link to comment https://qualityforum.zeiss.com/topic/14102-defining-points-using-cylindrical-co-ordinates/#findComment-73286 Share on other sites More sharing options...
