Filtering on the monitor screen
Hello to everyone,
I have 10 machines that machine the same part. With Autorun, I measure parts of 10 machines at once. I want to see the last 20 measurements of each machine after each measurement.
Is it possible to apply filtering while on the monitor screen to see the last 20 measurements measured after the measurement is finished?
I tried very hard but it didn't work.
I use one program. For this, I don't want to open piweb and filter every time. Filtering on the monitor screen will speed up my work.
Thank you
Are you talking about your measurement selection?
If you are talking about the measurement selection, make sure you can see it by going to Tools - Show measurement selection
or are you talking about the actual filter?
Thanks for your answer, I think I was misunderstood.
I want to save my results in 2 different formats.
1. the result of the last measured piece.
2. The last 20 measurements of that machine.
But I want to select the machine number by adding filtering to the title part of the report showing the last 20 measurements.
My aim is to be able to filter without opening Piweb. 659_937ccfd68e0e1c3a5f0ed39763ae2dd5.png
Hello richard,
I want to make Machine filtering by adding an option to the title section as follows. My goal is to be able to do this without opening piweb.
I added as below, but filtering did not work.
I'm sorry for my bad english. I hope I could explain. 2500_310bcdcca046e9a70b17ae375193b184.png
