Alignment with Datum Targets and Geometry
I have a cylindrical part, laying along the X axis. The drawing calls for 4 Datum A target points, 2 at each end. Imagine the part sitting in 2 90° v-blocks. Datum B is the end face. And Datum C is a flat in the Z plane on the top.
I created a Geometry Best Fit of the 4 Datum A target points, with full translation and rotation. Next, I created a normal secondary alignment. I changed the Alignment reference to the previous GBF alignment and added Datum B plane for the X origin and the Datum C line for the planar rotation. Is this correct?
Screenshot 2020-11-09 090438.jpgFetching info... Screenshot 2020-11-09 085412.jpgFetching info... Screenshot 2020-11-09 085436.jpgFetching info...
I would fit cylinder to 4 points with locked radius. Drawing should contain base dimension for that. But i don't know if 4 points will not have issues with cylinder.
Or you can make 2 circles with locked radius and construct 3d line from them.
I can't understand the logic of adding datum target to this like simple geometry.
Datum targets are added for complicated contour or geometry that can't be work with standard practice.
I think that four points for designing Fixture.
I can see the dilemma. Datum A is supposed to constrain Y,Z location, but with 4 points arranged like that, how can it? The diameter/center point of the part could be anything and still fit on those 4 points. Maybe you could forget it's a cylinder and think of it as an irregular shape but that doesn't change the inability to establish Y,Z nominal. I maybe wrong, I don't know.
Absolutely. When I looked at Y14.5, it said 2 sets of 3 equally spaced points at each end of the cylinder should be used.
Check out paragraph 4.24.10 Also, datum targets on standard geometry could be used to identify where measure or fixture the part.
If the Datum targets represent the contact (tangent) points of the part resting in v-blocks, why not Construct
a theoretical cylinder from those four points and use that for the spatial rotation in your alignment?
Are the Y & Z coordinates for the datum points .4808? I want to try something out.
Create the 4 nominal datum points at .4808 Z & X (whatever in Y) and construct two
symmetries. Construct a 3d line from the symmetries = X+ (in your example) Spatial
or Planar Rotation?
Not to sound ungrateful but nobody answered my original question about how one might create an alignment using datum targets and geometry.
Let's forget about 4 target datums on a cylinder and make it a multi-level plane-like surface with 4 datum targets at different heights.
I don't know if I'd let it tumble is all 6 axis. I would suggest only having Translation in the Y, Z, and Rotation in the Y, Z active.
Have you tested it to see if the results you are getting make sense?
I've just started using Geometry Best Fit, and I actually have a lot of questions myself regarding it.
Typically the experience I have had with a 3d Best Fit though would be in the Base Alignment, and looped at least 3-5 times. Your case is unique though.
