LMC
I have a true position of an OD to an ID. Both allow for LMC, but Calypso is only
giving me LMC from the feature (OD) being evaluated, and not the Datum (ID)?
OD Ø
Nom = 7.8740
Act = 7.8606
Dev = .0134
Tol = .025
Position tolerance = .051
Bonus = .0116 + .051 = .0626
That's what shows up on my report, but nothing from the datum feature which is using LMC in the characteristic.
My guess would be that it's ignoring the datum bonus because it doesn't need it?
The modifier on the Datum is not bonus tolerance. It is a virtual boundary. You will not see additional tolerance. Typically it would be reducing the error reported as the datum is allowed to shift now.
If you throw this into a Bore Pattern, it will plot the MMB/LMB for you.
Thanks guy's, I actually forgot all about that being datum shift.
And, I just read a post about that a few days ago. Short term
memory go bye, bye. 😃
