Converting a program from V6.8 to V6.4
This answer is not correct!
Yes it is possible to trick the system into accepting the files, but this will lead to unforeseeable problems!
The reason why programs are not forward compatible is because with new Versions there are new features.
How should an old Version handle a program that relies on features that it simply doesn't have?
Thanks for the reaction! This looked like it was the solution but when I opened the program in V6.8 and set the parameter to V6.4 and opened that same program in V6.4 I got the warning that the program can not be opened..
After I pushed the help button and read the information from Calypso it said that this option is only capable of converting to newer versions, lets say from V6.4 to V6.8 instead of the other way around.
