Stylus System Name Change
Hi All,
I was wondering in there is a way to change the name of a stylus system without importing a SSC file?
Back story: When we updated the software to 2020 on our three machines somehow one of our machines has a stylus name of 4mm Extended and the two other are named 4mm EXTENDED. Is it possible to make this change without having to requalify?
Thanks
Mike
Hello, this is how I would do this :
1) Export the one you want to rename (pcf)
2) Import the one you just export and then rename it (pcf)
Don't know if you can rename in Calypso (seems no).
Guillaume
If you go into the Stylus System Management, you can select, then right-click on the stylus system in question, then select copy, and it will prompt you for the new name.
