Points of geometry on CAD model
Hello all,
I would know if some of you know hot to show measured points of a geometry in cad view. For example, I have a 2d line geometry (see picture) measured here.
I would see measured points on my CAD view and don't know how to do it. I know how to do it with curve (2d curve and profile calculation) but is that possible to do with standard geometry ?
Thanks
Guillaume
https://qualityforum.zeiss.com/topic/14200-points-of-geometry-on-cad-model/
CAD - Evaluation - Result tab, click "display" I choose Spheres under
Presentation. Check color gradient to show plus/minus material conditions.
Click on the Characteristics tab - Display Banners.
You can set those settings to what you prefer, that's just what I use.
Thanks for your answer !
Which result do I have to choose if I want to show my points ? I've tried TRUE POSITION and don't work (seems to show form default). I want to see measured points compared to nominal geometry.
I can do it with curve and then using profile calculation (but not working with 2d line).
Select one characteristic ( some characteristics does not have all options ) - in CAD -> Eval is at bottom checkbox for display min/max.
For examply - Line profile does have min/max, but Surface profile does not. So you must search for chars. which have this option.
After enabling it it works for all chars.
