[Ke...] Posted July 15, 2020 Share Posted July 15, 2020 Good afternoon everyone, I have a Crazy Duramax that was running great 5 days ago, now the operator is getting bad parts. I look at Data and see the points are NOT perpendicular to the surface (Photos attached). So I did the following with a known Good Master part. 1. Check the Fixture, it was tight and square to the table. 2. Probes are clean and tight 3. Re qualified probes 4. load part, made sure it was seated properly 5. Manually pick up Base Alignment Still got Skewed results......So I shut everything down for 15 mins than did steps 1 thru 5 again still got bad results. Are all Duramax's this finicky??? I also got an Weight error for my Master probe to add to the mix.weight.pngface form.pngcylinder form.png Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/ Share on other sites More sharing options...
[Cl...] Posted July 15, 2020 Share Posted July 15, 2020 Something else could be going on, but I've only seen this with star probes. It's a weight/balance issue. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74216 Share on other sites More sharing options...
[Ke...] Posted July 15, 2020 Author Share Posted July 15, 2020 The probes seem to be the same probes when I left. I wonder if the operators crashed it didn't tell anyone. Thanks for the idea I'm going to double check the probes to make sure there the sames as before. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74218 Share on other sites More sharing options...
[Cl...] Posted July 15, 2020 Share Posted July 15, 2020 Take a look at the status window for crashes. Also, If you don't have it, I would recommend getting CMM observer. Just be advised in advance that the machines firmware must be up to date for it to work properly. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74220 Share on other sites More sharing options...
[Gr...] Posted July 15, 2020 Share Posted July 15, 2020 We had the same issue 4 months ago. Turned out the spring was broken in the Vast XXT TL1 probe head. Had a tech come out removed the head, gently shook it and the noise you could hear was what he called the "death rattle". Very expensive replacement. Cannot remember if it was $3000.00 or $5000.00 for head exchange price. Good Luck Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74222 Share on other sites More sharing options...
[Cl...] Posted July 15, 2020 Share Posted July 15, 2020 A new XXT is around $6,000 Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74224 Share on other sites More sharing options...
[Ke...] Posted July 15, 2020 Author Share Posted July 15, 2020 The Duramax came with another head? Is there any diagnostics tools built into calypso, I know Zeiss tech have a program. Anyone have a guide to changing it out? is it similar to a vast XT switch it out and just requalify all probes? Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74226 Share on other sites More sharing options...
[Cl...] Posted July 16, 2020 Share Posted July 16, 2020 Shut down Calypso, unscrew the XXT and install the new one. You may have to go to the Zeiss portal (You'll have to register if you haven't already) and download the device activator. Re-boot Calypso and requalify probes. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74228 Share on other sites More sharing options...
[To...] Posted July 16, 2020 Share Posted July 16, 2020 In my opinion, those point angles are pretty normal for a star probe on an XXT sensor. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74230 Share on other sites More sharing options...
[Cl...] Posted July 16, 2020 Share Posted July 16, 2020 Yep, that was my original response. Even though the visual is bad, results are good. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74232 Share on other sites More sharing options...
[Ke...] Posted July 16, 2020 Author Share Posted July 16, 2020 Thank you for all your help and response, but I'm puzzled that the Master part checks bad on this Duramax and good on the other. I'm going to change the head tonight after 1st shift leaves and see if this fixes the results. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74234 Share on other sites More sharing options...
[Jo...] Posted July 20, 2020 Share Posted July 20, 2020 Has this exact issue with our Duramax with XXT right out of the box and was told it was normal. Notice that the stylus actually pivots/tilts on an XXT as opposed to traversing like an XT head does. I'm pretty sure this isn't the problem. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74236 Share on other sites More sharing options...
[Ja...] Posted July 21, 2020 Share Posted July 21, 2020 We get angled vectors with our XXT / RDS setup all the time, when using star styli. Tech support and even the infamous Ryan Stauffer said it was pretty normal with passive scanning and star styli. Your form error and Sigma values will tell the true tale. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74238 Share on other sites More sharing options...
[Lo...] Posted October 27, 2020 Share Posted October 27, 2020 I am having the same issue, not only with the vectors, but results from the Contura to the O-inspect machines. The Contura has the XT and the O-inspect does not. Machines are not correlating, I am using the same routine that was written for the Contura. I did not write the program, second day at this company and have been tasked with figuring it out. When I wrote a quick sanity check program using a 1,2,3 block. Got different results using the star probe compared to a down probe (.100mm), with similar looking vectors as far as pointing up or down in the Z axis. All of the down probe's vectors, as well as probe 2&4 (front and back) were parallel or perpendicular. I've lightened the stylus by creating a T-Probe , instead of a star and am still not seeing a difference. I've powered it all down and re-Qualified everything, several times with no remedy. Can anyone shed some, additional, light on this? I'm stumped. Link to comment https://qualityforum.zeiss.com/topic/14232-actual-points-not-perpendicular-to-surface/#findComment-74240 Share on other sites More sharing options...
