[Ni...] Posted October 26, 2020 Share Posted October 26, 2020 Hi All, Can anyone explain how I insert a Ø.9375" theoretical ball between the 30° angled faces to determine a value for the 2.534" distance from center?.9375 Ball Dim.docx Link to comment Share on other sites More sharing options...
[Ch...] Posted October 26, 2020 Share Posted October 26, 2020 Construction>Circle in Contour fit ??? Link to comment Share on other sites More sharing options...
[Ri...] Posted October 26, 2020 Share Posted October 26, 2020 There's an instruction of how to do it with Planes, but if you measure it as lines you can use the construction - tangent feature. Link to comment Share on other sites More sharing options...
[Ni...] Posted October 26, 2020 Author Share Posted October 26, 2020 Thank you fellas! I used the tangent feature as the circle in contour fit could only be used with 2d or 3d curves. Lines are much easier to generate IMO Link to comment Share on other sites More sharing options...
[Cl...] Posted October 26, 2020 Share Posted October 26, 2020 If planes, measure both and move them half the nominal diameter, then Intersect them. Recall the intersection into a theoretical sphere. Link to comment Share on other sites More sharing options...
