[Ja...] Posted September 2, 2020 Share Posted September 2, 2020 I've heard that if I use a loop for base alignment and give it a condition, the measurement accuracy will be enhanced. I was trying to make a loop but I only can make it in characteristics menu. (Base alignment features only appear in features menu.) Can anyone help me apply a loop? Thanks Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/ Share on other sites More sharing options...
[SH...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. Loop will increase the reptetablity of your program, accuracy depends upon on lot of other factors such as temperature, strategy, evaluation etc. I think you are talking about base alignment loop, you can create it inside the base alignment definition template. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74532 Share on other sites More sharing options...
[Ja...] Posted September 2, 2020 Author Share Posted September 2, 2020 So, the looping for the base alignment is not related to the accuracy at all? I have seen a post that said like a stylus checks around the base alignment until it satisfies the condition you give. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74534 Share on other sites More sharing options...
[Cl...] Posted September 2, 2020 Share Posted September 2, 2020 It absolutely affects accuracy. Someone might correct me on this, but in layman's terms, each time a loop is initiated, the feature points are probed closer and closer to their actual nominal coordinates & vectors. It keeps doing this for as many times as you've set it to, until the alignments squareness falls at or below the sigma value you assigned to it. Garbage in, garbage out. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74536 Share on other sites More sharing options...
[SH...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. Accuracy of your measurement depends upon accuracy of the machine if your working in prismo machine you will get one accuracy ,work in micura machineis you will get another accuracy It depends upon the your probe qualification perfection. It depends upon the temperature inside your room, It depends upon either you scan or touch trigger. It depends upon your filters and outliers. So lot of things.. Definitely loop will increase your accuracy , but accuracy is not just a loop.Iterative Alignment.pdf Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74538 Share on other sites More sharing options...
[Ke...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. Agreed. There are many things that can affect accuracy, and a stable & repeatable base alignment is one of them. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74540 Share on other sites More sharing options...
[Ma...] Posted September 2, 2020 Share Posted September 2, 2020 Loops in base alignments are needed for RPS alignment. If you have just simple features like plain, circle on cylinder and lot of free space around ( aka you are not measuring circle on narrow place ) then you will don't have any bonus from loops. If you are measuring only machined parts, then it's easier compared to my job - measuring forged parts which are often deformed ( aka plain is not straight - it's bended in many angles ... ). Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74542 Share on other sites More sharing options...
[Da...] Posted September 2, 2020 Share Posted September 2, 2020 To answer how to do it... Open your base alignment, click on the loop button, in the text box type in baseSystem().valueA<0.001 or whatever limit you want. You will set the number of times at the top of that window, I usually use 1/5/1. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74544 Share on other sites More sharing options...
[Am...] Posted September 2, 2020 Share Posted September 2, 2020 Just want to point out that to put a formula into the base alignment loop break condition it requires PCM. If you don't have PCM you are going to have to live with just putting in the amount of times you want it to loop the base alignment and deal with the program taking longer than it needs to. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74546 Share on other sites More sharing options...
[Th...] Posted September 2, 2020 Share Posted September 2, 2020 Please sign in to view this quote. The break condition David posted works without a PCM license. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74548 Share on other sites More sharing options...
[Am...] Posted September 3, 2020 Share Posted September 3, 2020 Please sign in to view this quote. For me it does not. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74550 Share on other sites More sharing options...
[Cl...] Posted September 3, 2020 Share Posted September 3, 2020 That's odd? Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74552 Share on other sites More sharing options...
[Th...] Posted September 3, 2020 Share Posted September 3, 2020 What's your condition look like? It absolutely should not be demanding a PCM license to use. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74554 Share on other sites More sharing options...
[An...] Posted September 3, 2020 Share Posted September 3, 2020 Please sign in to view this quote. Totally agreed! Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74556 Share on other sites More sharing options...
[SH...] Posted September 4, 2020 Share Posted September 4, 2020 I have observed a good improvement while I use threaed holes features in alignment. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74558 Share on other sites More sharing options...
[Ma...] Posted September 4, 2020 Share Posted September 4, 2020 Of course you can have better results - imagine you are measuring small bolt ( ie 6mm ) but your initial center for that bolt is for ex. 1,5mm offset. Then how precise can be inital touches? Or if you are measuring threaded hole with line scans upwards and filtering - it will also affect results. But if you are measuring clean big cylinder idealy with start align, then loop don't give you more than take your time 😕 Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74560 Share on other sites More sharing options...
[De...] Posted October 20, 2020 Share Posted October 20, 2020 Looping the base alignment is good to use if you fixturing is not the best. It is also good for special base alignments like when your part is all non-standard geometries. Can't remember the name but it is something like 3d freeform or 3d geometry. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74562 Share on other sites More sharing options...
[Sc...] Posted October 22, 2020 Share Posted October 22, 2020 I totally forgot how to remove the loop alignment in feature. See screen shot.Screenshot 2020-10-22.png Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74564 Share on other sites More sharing options...
[Ma...] Posted October 22, 2020 Share Posted October 22, 2020 Right click on feature and select loops. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74566 Share on other sites More sharing options...
[Sc...] Posted October 22, 2020 Share Posted October 22, 2020 Martin, I clicked on feature tab and nothing shows up on right click. Can you give me a screen shot where exactly it is? Please. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74568 Share on other sites More sharing options...
[Sc...] Posted October 22, 2020 Share Posted October 22, 2020 I understand that right click on each feature has loop in the menu. The question is the whole measure plan is looped as you can see highlighted on my screen shot on previous post. (1,30,1) is going to run the program 30 times....I created this program about 2 years ago and now I don't remember how got the whole program looped. I want to remove it so I can run program once. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74570 Share on other sites More sharing options...
[Ma...] Posted October 22, 2020 Share Posted October 22, 2020 Sorry for misreading. I am not at machine now - perhaps someone knows - never did this for whole plan. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74572 Share on other sites More sharing options...
[Sc...] Posted October 22, 2020 Share Posted October 22, 2020 I know right click on each feature has "loop" in the menu. As you see on screen shot the loop is for a whole measure program. (1,30,1) meaning it run program 30 times. That is the issue I am trying to remove the loop. Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74574 Share on other sites More sharing options...
[Ch...] Posted October 22, 2020 Share Posted October 22, 2020 Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74576 Share on other sites More sharing options...
[Sc...] Posted October 22, 2020 Share Posted October 22, 2020 Chad...you hit right on the nail. WHEW.....running Subsequent Evaluation was a pain...it ran 30 times!! My goodness....what a day I had. Again thanks Chad Link to comment https://qualityforum.zeiss.com/topic/14276-alignment-loop/#findComment-74578 Share on other sites More sharing options...
