Caliper Distance + X/Y/Z Locations not matching
Hello all, I'm having some issues getting these .940 /Y locations to come in by using a secondary alignment on the features (the 1/4-20 thread minor diameters) and reporting the X and Y locations from the dialogue box of the features.
However, if I use a caliper distance from minor diameter of the threads to the diameter of that middle bore, the results are within the allowed +/- .005". Why would the results vary that much between each method and how can I be sure I'm reporting the correct results?
As always, any help is appreciated!
Thanks,
Zach
Caliper Distance Results: 2084_623edb200426e2663cae7b70b851f0c4.png
Results using Secondary alignment and reporting X/Y Locations (please ignore that the wrong box is checked): 2084_acefbf7b4338fee37ac7c2b7433d99ee.png
The secondary alignment I'm using: 2084_df9381059f4874c61a00d5f36eb859c5.png
The portion of the print being used for reference: 2084_4f6e9f27b265d7a6b251d5cf9279abee.png
Mainly because of A1 nad A2 angles. With caliper distance you can choose middle, min or max. But min and max will work with diameter. If you use data from cylinder as 3d-line then you can report min and max from axis of that cylinder.
Also - only caliper distance uses alignments - so it is perpendicular to axis of choosen alignment
Is there any way to report those X/Y locations as they appear in the caliper distance dialogue box? I have many similar parts that are coming through right now that have this same check and I'm trying to avoid having to do a caliper distance characteristic for each .940" check. I'd rather be able to set the feature to a secondary alignment and report the locations through that dialogue box if possible, but they keep checking out of tolerance when they are in fact not out of tolerance (verified with a height gage).
What problem do you have with caliper distance usage?
Just to mention - don't use X origin from 1.996 cylinder - use plain instead.
You can choose max inscribed evaluation for threaded holes for better position calculation.
And report only Y and Z axis 😉
I guess I don't have anything against the caliper distance except for that it's not displayed as a "location".
I couldn't get the holes to come in how they should, so I'm just going with the caliper distances to save time now. I really want to figure out why the numbers are a few thousandths different from one method to another though.
