Base alignment
When actual values of points for base alignment are not zero, how do you make them zero?
For example, a plane for the base alignment has 4 points. 2 points are really close to zero but the other 2 points are like 2-3 mm off.
I think they all are supposed to be the exact zero.
Two,three mm off 😱
Your production people has a serious problem I think....
What type of plane it is ??offset plane,recalled plane or usual plane??
So I have a point, 2D line and a plane for the base alignment.
When I execute base alignment all the actual values are not zero.
You seem to be constructing features for the Base Alignment, that don't need
to be constructed. Any particular reason why you are doing it that way? That's
kind of the long way of doing things. Not being critical, just asking.
I'm learning how to program it by myself and I only have an example program.
The example program that I was given seems like have features just like what I have.
Got it. If you probe a minimum of 3 points on a planar surface, Calypso will recognize it as a plane.
Two points in succession for a 2d line. Two 3 point circles at different heights for a cylinder, etc. This
saves time and allows you to apply filters/outliers/evaluations.
It is not clear on how are you setting up your base alignment but I am guessing you use standard method with plane datum X for spatial rotation, line datum Y for planar rotation, datum Z point as two of your origin co-ordinates and datum X as the last origin co-ordinate. In that case, if you look into the datum X, you should have one co-ordinate set to 0, and both projection angles set to 0. In datum Z, you should have two co-ordinates set to 0 and in datum Y, one of the projection angles set to 0. As for other values being off, there might be different reasons. For e.g. x,y,z values of that point 6 might be just due the actual point being at that offset from origin or some other reason. I cannot say for certain unless you provide some information on how the parts looks.
  • 4 weeks later...
Reporting the points separately then recalling them into a plane could yield info for manufacturing potentially. I know this is really basic, but make sure your stylus and part are both clean and that your stylus is qualified and yeilds good sigma and radius values.
