[Gr...] Posted October 19, 2020 Share Posted October 19, 2020 Hello everyone! I have a following problem. I need to calculate how many time elasped between 10 last measurements. I need to create a chart based on this value. In my database I have a position K4 - Time (format: Data). In Piweb Designer I can calculate this value, but only in field Text: I used following formula: ${(Qdb.Measurement(4,-1) - Qdb.Measurement(4,-10))} and it works 😉 in Piweb Designer. Can I calculate this value directly in Piweb Planner? or, Can I created a chart based on value calculated in Piweb Designer? Thank you for help and stay healthly! Grzegorz Link to comment https://qualityforum.zeiss.com/topic/14318-piweb-planner-creating-a-calculated-characteristic/ Share on other sites More sharing options...
[3e...] Posted October 19, 2020 Share Posted October 19, 2020 As far as I know, you can't use measurement attributes in calculated characteristics. Why not create a calculated measurement attribute? I would have to try this out, and I'm not sure it would work so I'm just spitballing at this point. Why not run a server job 'Modify Measurement Attribute' and if the calculated date = n. def then Calculated Date = ${(Qdb.Measurement(4,-1) - Qdb.Measurement(4,-10))} I'm not sure how that would "array" out to other measurements though, since you're using explicitly -1 and -10. You'd have to run the job more frequently than the measurements would be incoming. Or, you load your measurements into a report and then use the Hyperlink/action "Write measurement attributes" and have the variable in there. Then have a following action of Write Changes. I've not tested any of these but this is where my mind goes when I think of a potential solution.. Link to comment https://qualityforum.zeiss.com/topic/14318-piweb-planner-creating-a-calculated-characteristic/#findComment-74832 Share on other sites More sharing options...
[Gr...] Posted October 20, 2020 Author Share Posted October 20, 2020 Hi Laura, Thanks for your interesting on my problem 🙂 What is it - calculated measurement attribute? this is a variable in Piweb Planner? I admit that I'm a beginner in Piweb's stuff. Link to comment https://qualityforum.zeiss.com/topic/14318-piweb-planner-creating-a-calculated-characteristic/#findComment-74834 Share on other sites More sharing options...
[3e...] Posted October 20, 2020 Share Posted October 20, 2020 By calculated measurement attribute, I meant, a measurement attribute that is defined by a variable, sorry. A variable which would be a calculated value.. Edit: And yes, you could try setting up a server job in Planner. Again, I don't know the syntax that you would need to use or if it's possible but this would be where I would go first. Link to comment https://qualityforum.zeiss.com/topic/14318-piweb-planner-creating-a-calculated-characteristic/#findComment-74836 Share on other sites More sharing options...
