True position troubles
The part is a cannulated cylinder about 8" long, on the left side is a slightly larger OD cylinder that is made up from two 100 degree radial segments 180 degrees apart, (not a full circle) separated by two flats 180 degrees apart. Datum-A- is an ID only about 2" long on the right end of the part. I'm reporting the position (.007 -A-) of the larger OD back to -A-. The segmented OD is going to be a problem, and datum -A- is just to short. They say they can't straighten the part less than .005". I'm just looking for ideas to I'm prove my results. Thanks in advance.
You want to improve your results by strategy? Or you want to prove your strategy? 😃
Anyway, separated circle ( cylinder ) : choose slower scanning speed or use touch points instead. Slower speed gets less masked points.
MMC for datum A would be nice 🙂 If it's bore than it can be difficult for concentricity. I don't know usage, but couldn't you use circle on left side? I dont' believe that is left side without support.
