[To...] Posted October 19, 2020 Share Posted October 19, 2020 Hi I am outputting table files for later evaluation in QDA, which is a program similar to Q-DAS. My issue is that when a nonconformity on a part is found when doing inspection in our Contura it will output a table file without note if the part was approved or not. So my question is. Is it, without PCM, possible to make a button which will make the table file when pressing Approve, Not approved and mark the table file with some kind of note that I can pickup and filter on? Link to comment https://qualityforum.zeiss.com/topic/14326-output-table-file-when-pressing-approve/ Share on other sites More sharing options...
[86...] Posted October 19, 2020 Share Posted October 19, 2020 You can do something like this with PiWeb, but I'm not sure about table files. Link to comment https://qualityforum.zeiss.com/topic/14326-output-table-file-when-pressing-approve/#findComment-74870 Share on other sites More sharing options...
