Wrong Nominal on a Length of Perpendicular
I have four Length of Perpendicular dimensions on my Characteristics list. When I setup my perpendicular under the features tab the nominal isn't exact to match the print, so I input a new nominal under the characteristics tab. When I do that and run a part it keeps the nominal from the features tab and not the characteristics tab. Is there a setting that I am missing somewhere? Any assistance would be greatly appreciated.
It determines how tolerances are calculated and displayed when nominals/actuals are negative. With absolute value it behaves like you would expect for most drawings: Nominals are treated as an absolute (signless) value and tolerances are calculated accordingly. With number scale it takes the sign of the nominal into account and calculates the tolerance according to the positive or negative axis direction.
  • 7 months later...
