PCM to no PCM
I'm trying to run a PCM program on a machine that doesn't have
PCM. I deleted the .PARA files, other model, etc., but when I try
and run it, I get an error message; (Option Not Available PCM).
Programs with PCM code will run on machines without the PCM module - but you cannot debug or open the code on the non PCM machine.
Sounds like you have a different issue?
