XYZ nominals/actuals in freefrom
Is it possible to report the XYZ nominals and actuals of the points when using free form?
I created a section of 55 points and would like the individual points into the characteristics report.
I'm thinking I might just have to use space points and click X,Y and PtDist.
Lincoln
I decided to use curve instead of freeform. I was able to figure out how to export the data to a txt file or notepad whatever you call it. The engineers will be able to see X,Y,Z and the ijk.
Lincoln
If you turn on the additional printout for the Profile inside of Characteristics Settings Editor - Report - Additional Report it will show you the deviation for each point measured.
