Probe angle after run...???
I have an XT, so i cant show you exactly, but if you go into 'Stylus System', the tip shown in the 'Stylus Name' dropdown box will be the angle that Calypso goes to when it pick up out of the rack.
Make sure whenever you go into the Stylus System menu, that you always leave it with 0,0 selected.
Whichever location you last calibrated, it will come at that location when you call it from the rack. After recalling from the rack, manually calibrate it at the last position you want it to remain.
When you are in the Probe System Qualification window what ever stylus is active when you hit the OK button becomes the favorite Stylus, meaning it will rotate to that position when it comes out of the rack first. Best habit is to go back to the Z- (Stylus 1) before hitting that OK button.
