Multiple Measurement View
With the report open, press the F6 Key to enable the Selection sidebar (or go to Navigation > Show measurement selection).
On the measurement tab, change the value from 10 to 100. Or use the selection parameters such as date, or measurement attribute (ie. if you were searching for a particular work order) to find the measurements you are looking for.
