Status window
You have other alignments with the same names. You may have deleted "Measurement Plans 267,268,269", etc.. but perhaps their alignment did not get deleted also from C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\basesystems. When you create a base alignment, this is where they typically get stored.
It looks like the status window says it gave it another name, not sure if it rolled up the last digit, or added (2) to the end, etc.
Are you saving your plans as "Measurement Plan 267,268,269, etc?
I'd suggest giving it a more descriptive name for easier reference.
Good luck, and happy measuring !
CR
I don't save unwanted program directly, while closing it ask do you want to save I say yes, because I want to save my regular program update.Later I delete all the unwanted program weekly basis from the folder. That programs are useless and i don't give it a specific name. Those are default names.
When you create base / start alignment then it saves as actual program name. When i create new program from template i always first save as new name, then i am creating elements and alignment.
But when you establish base / start alignment, then it is saved automaticaly. You should clear these unwanted alignments too.
In main window menu - somewhere under load and save measured points.
