[Lo...] Posted October 6, 2020 Share Posted October 6, 2020 Hello Everyone, I run several parts that are either in millimeters or inches. How can I get the results in millimeters instead of inches? Thank You Link to comment Share on other sites More sharing options...
[Mi...] Posted October 6, 2020 Share Posted October 6, 2020 You can change it for an individual program in the Measurement Plan Editor Features menu in the second tab, under Units. It can be changed globally in Settings -> Environment, I believe. Link to comment Share on other sites More sharing options...
[Ni...] Posted October 6, 2020 Share Posted October 6, 2020 Change your settings using the drop down menu: Extras-> Settings-> Environment-> Language Link to comment Share on other sites More sharing options...
[Jo...] Posted October 6, 2020 Share Posted October 6, 2020 Please sign in to view this quote. If you want to view in MM just change it in the program and run subsequent evaluation, it will update. In an instance where it is in MM and you need the answer in inches for an operator adjustment, use a conversion formula in a result element Link to comment Share on other sites More sharing options...
[Lo...] Posted October 6, 2020 Author Share Posted October 6, 2020 Awesome thank you everyone! Link to comment Share on other sites More sharing options...
[Ja...] Posted October 6, 2020 Share Posted October 6, 2020 If you are looping your base alignment, you will want to change that too. It doesn't change on it's own. If you create the program in inches and loop to .002", changing the program to millimeters will then be trying to loop to .002mm. Link to comment Share on other sites More sharing options...
[Am...] Posted October 9, 2020 Share Posted October 9, 2020 Please sign in to view this quote. Wow, that seems like something they should fix. Link to comment Share on other sites More sharing options...
