Another "How'd you check it? "
That'll work ! I was less elegant. I created a 3d line from the Id cylinder and intersected with the cone shell. Used a bit of trig to fix the Z axis measurement to a perp meas in results element. We also had our Eng. give us a gage point on the surface of the cone...
The numbers varied slightly due to the actual angle varied a bit from nominal. The print is projecting a LONG ways to the measurement. I totally agree WHY !!! 🤣
  • 1 month later...
