PC-DMIS
Please someone help! I'm pretty sure I've asked this a million times to whoever would listen...
How can I constrain a circle in PC-DMIS the same way I can on Calypso?
I've found ZERO about this anywhere accept from Hexagon but I do not trust their method and it is extremely time consuming.
For the time being we just take polar points..
Have you tried creating a generic circle and constraining your actual MEAS values - For example in the MEAS X you could put CIR1.TX which would place the theoretical X value of circle CIR1 into the measured value for the generic circle. Populate the generic feature with actual and theoretical values as you need.
  • 5 weeks later...
