Alternative to Free Form Surface
One of our O-inspects that we'd like to use for a new program does not have FFS (It does have curve). We have a part with several surface profile callouts. The O-inspect camera would be the fasted and best way to measure these parts. Without having FFS on this machine is there an alternative method for evaluating surface profile?
Without Free-Form your only choice is using a standard geometric shape. Or measuring line profile of all the curves, and reporting the maximum - that would get you closeish.
The Point-Cloud only gets you a heat-map, not an actual Profile result.
The General Surface is only touch-points, recall feature points doesn't work with it.
