[To...] Posted September 17, 2020 Share Posted September 17, 2020 I have an angled plane (Datum C) which has an Angularity call out to A and B. In the help, it states the nominal angle is from the feature to the first datum, which happens to be 90°. It appears to not consider the other angle. If I use datum B as the Primary, then the nominal angle of the feature appears and the results are more realistic. Is this a case where I should ignore Datum A and just use Datum B?Angularity 1.jpgAngularity 2.jpgAngularity 3.jpg Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/ Share on other sites More sharing options...
[Cl...] Posted September 17, 2020 Share Posted September 17, 2020 I would say yes, because of B's orientation relative to C, it make perfect sense to me. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75902 Share on other sites More sharing options...
[To...] Posted September 17, 2020 Author Share Posted September 17, 2020 I guess I didn't read ALL of the help, correctly. So, I should ignore what is shown on the drawing and give them the results they are looking for....Angularity 5.jpg Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75904 Share on other sites More sharing options...
[Me...] Posted September 17, 2020 Share Posted September 17, 2020 If -A- is the Primary then that's the angle you report. B is stopping a rotational DOF as the secondary. Not sure why your result is so out. Have you tried rotating your coordinate system so that C is 90 deg to A and then checking it? Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75906 Share on other sites More sharing options...
[To...] Posted September 17, 2020 Author Share Posted September 17, 2020 Please sign in to view this quote. The angle is relative to B, so I'm guessing the drawing should have been to B then A. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75908 Share on other sites More sharing options...
[SH...] Posted September 17, 2020 Share Posted September 17, 2020 Please sign in to view this quote. Wonder, in your post there is always something new to learn . Don't ignore the drawing, you should discuss with your customer. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75910 Share on other sites More sharing options...
[Ri...] Posted September 17, 2020 Share Posted September 17, 2020 They are probably wanting to use A as a constraint. If you constrained B to A would you get what you are looking for? I see this with Runouts all the time. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75912 Share on other sites More sharing options...
[To...] Posted September 17, 2020 Author Share Posted September 17, 2020 Please sign in to view this quote. That was the first thing I considered when I thinking about using B for the Primary. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75914 Share on other sites More sharing options...
[Ma...] Posted September 17, 2020 Share Posted September 17, 2020 I actually have a czech translation so i don't know it's exact name, but wouldn't be enough angle between elements? Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75916 Share on other sites More sharing options...
[To...] Posted September 17, 2020 Author Share Posted September 17, 2020 Please sign in to view this quote. No. Angularity is an orientation control and uses a tolerance zone similar to parallelism and perpendicularity. The angle is BASIC I've actually seen an argument for using one symbol for all 3 and just specify the angle relation ship between the feature and the datum... Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75918 Share on other sites More sharing options...
[To...] Posted September 17, 2020 Author Share Posted September 17, 2020 Please sign in to view this quote. That's fine if you address it when you're quoting it but at final inspection, it's a little too late. Sometimes, your customer is not the final customer. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75920 Share on other sites More sharing options...
[Ri...] Posted September 17, 2020 Share Posted September 17, 2020 Yeah. Angularity is not a tolerance on the angle. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75922 Share on other sites More sharing options...
[Ma...] Posted September 17, 2020 Share Posted September 17, 2020 Thanks, I just realized it 🙂 We have translation misunderstood. Then you have to come with another strategy. Maybe rotated coord system and recalled elements? Or if it help some 3dline as 2nd base to rotate to desired angle measuring? Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75924 Share on other sites More sharing options...
[Me...] Posted September 17, 2020 Share Posted September 17, 2020 Please sign in to view this quote. I guess I'm misunderstanding. But, if there is a basic angle drawn that's to B instead of A, it doesn't override the FCF. The FCF takes precedence. The same as if someone daisy chains a bunch of holes with basics center to center, when the actual hole locations are all to a common datum. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75926 Share on other sites More sharing options...
[Br...] Posted September 17, 2020 Share Posted September 17, 2020 Please sign in to view this quote. Right and actually there is a basic to A. It's just implied 90°. Implied 90° basics are a fundamental rule of Y14.5. Can you imagine having to put every 90° angle on a drawing? Every position tolerance of a hole that is perpendicular to the primary datum feature would have to include 90° basic angles to define their orientation relative to the DRF. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75928 Share on other sites More sharing options...
[To...] Posted September 18, 2020 Author Share Posted September 18, 2020 I think some of you are missing the point. I understand the hierarchy of a datum reference frame but in my example, when you follow it in an Angularity characteristic, i.e. A = Primary and B = Secondary, Calypso creates a tolerance zone equivalent to 2 parallel planes that are perpendicular to the primary and parallel to the secondary, when clearly, the tolerance zone should be parallel to the feature. If I use B as the primary, the tolerance zone is controlled by B, but it reads the nominal angle of C and rotates the tolerance zone by that angle. In order for A to still "act" as the primary, B would need to be constrained to A, like Richard suggested. An option similar to a position of an angled hole, where you need to use the Special button to rotate the coordinate system, might be a good fix.Angularity 5.jpg Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75930 Share on other sites More sharing options...
[Jo...] Posted September 18, 2020 Share Posted September 18, 2020 Please sign in to view this quote. Does Calypso "see" the angle as 2d ? For example if the part error was off in two vectors compound, would evaluating each Datum separately still produce the worst case condition ? Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75932 Share on other sites More sharing options...
[To...] Posted September 18, 2020 Author Share Posted September 18, 2020 Please sign in to view this quote. Good question. I just tested by importing points with 1 projection angle skewed 5° and another with both angles skewed 5°. Results reflected both variations. Update to something I posted earlier. I turned on CAD Eval and activated Tolerance Frames. It shows the frames being normal to the feature (C) but the results are calculated in 2 different ways. The data points on the 2 screenshots is using 0 dispersion. . .Angularity 6a.jpgAngularity 6b.jpg Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75934 Share on other sites More sharing options...
[An...] Posted September 18, 2020 Share Posted September 18, 2020 Deleted. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75936 Share on other sites More sharing options...
[An...] Posted September 21, 2020 Share Posted September 21, 2020 Deleted. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75938 Share on other sites More sharing options...
[To...] Posted September 22, 2020 Author Share Posted September 22, 2020 Please sign in to view this quote. What do you think about this option?angularity 7.jpg Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75940 Share on other sites More sharing options...
[An...] Posted September 23, 2020 Share Posted September 23, 2020 Deleted. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75942 Share on other sites More sharing options...
[Br...] Posted September 23, 2020 Share Posted September 23, 2020 Please sign in to view this quote. I think you found the ticket. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75944 Share on other sites More sharing options...
[To...] Posted September 23, 2020 Author Share Posted September 23, 2020 Please sign in to view this quote. I don't understand your last statement. Why is a mixture of both not helpful? I would assume both directions should be evaluated. Your method of using a theoretical 40° plane seems like it will work, as well as mine. However, for you Andreas, I will test both methods. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75946 Share on other sites More sharing options...
[Ma...] Posted September 23, 2020 Share Posted September 23, 2020 Tom - it seems like base coord of element is used. So for angularity between B and C must be used B as primary ( ie using Z axis for rotation ) - if A used as primary, then Y or X axis is used for rotation. So if you want to measure 90° you should rotate plane A by angle 40° ( or what is on drawing ), but i didn't tested it. At least this is what i see from numbers what you sended. Edit: 24.9.2020 6:55 Ok i did some tests and rotation of primary plane does not affect calc. So for measuring 90° you must use theoretical plane/line/3d line and put right angle to correct axis. Link to comment https://qualityforum.zeiss.com/topic/14470-angularity/#findComment-75948 Share on other sites More sharing options...
