Clearance Planes?????
Hello everyone,
I have been having an issue with setting my clearance plane. I have tried using different base alignments but I end up with the same thing and this error message. I can't seem to set the clearance plane correctly. I attached an image.
Lou, you can also highlight all your features and then go to CAD > CAD File > Automatic Healing > Build Geometry. Thiswill "trick" Calypso into thinking you have an actual CAD model, and will then activate the Clearance Plane from CAD model button. That might get you going.
It looks like you have a positive value for the negative X plane, and a negative value for the positive X plane. Also, your positive Y value is not enough to cover your part.
Oh man thanks that was easy and it worked! I "assumed" that those numbers were set in stone and can't be changed.
