True Position Bonus Tolerance Report
Hello,
I would like for my piweb pdf report to show exactly how it is on the image, but when It creates the .chr text file, I want it to only include the highlighted additional data, 5-1(M), and not include the 5-1, 5-1.Z, 5-1.X, from the true position.
Currently, it is reporting 5-1, 5-1.Z, 5-1.X but not 5-1(M) which is what I want.
Can someone give me a step by step on how to do that? or point me into the right direction. I am using the standard protocol template and there are a bunch of lines all jumbled up in there. I am not sure which one to modify or how. 3033_c276568552c00e4e5ad8c097f0c3444c.png
Thank You,
You can off the the additional printout in the characteristic setting editor, it will eliminate your X and Y values.
For vanishing real position I think pcm must.
The problem is I want the additional data to show. I want to see the X and Y values of true position after the run. But I don't want it to be included when calypso creates the .chr text file.
How can pcm be used with piweb?
  • 1 month later...
Click on the Measurement Tab, click the "Multiple report" button, click on "Mark Characteristics", "Additional report" drop down, change from "On" to "Off" to eliminate the X, Y, & Z values from being displayed.
