offline seat lag
I have a model of a small part and it seems to be causing the simulation to lag. Also when the auto fit button is hit it puts the part out in space even though my trihedron in near the part.
I had our cad guys look at the model and they said there is nothing out of the norm. I looked in the hierarchy tab to see if there were double models are anything screwy. It looks normal. What could cause the lag? The part a twisted mess with nothing co-planner.
Do you have your simulation parts on the screen(stylus/machine in background)? That will cause the part to get small with auto-fit button. As far as lagging on simulation....I have same issue quite a bit
Nothing going on in the background. The issue is with the model. When I generate the clearance cube around the part by going off the cad model, it uses a really big clearance cube about 30x the size of the part. There is nothing visible. In the hierarchy tab, there are only the normal model looking files and the trihedron.
