Stop and continue Program Calypso
If your running a Program and for some reason it stops. Select RUN and UNCHECK ' CLEAR EXISTING RESULTS" The program wil then continue on from where it stops and when it finished, your normal report will be produced.
Now, If you just want to do a simple Execute now and no report shows. Select Resources, Multiple Printout or which ever report you want. It will then show you your current Characteristics that have data.
Florin, What Silvio meant was if you select some features or characteristics and you right-click and select Execute Now it will run those features or characteristics but a report will not show up. To see the report, you will go to View and select the desired report format.
