Circle/Tangent Line Creation?
With this approach he won't get real tangent point. I think better use small section of points to create circle, then tangent.
Bigger angle will increase deviation.
I can't break in right now to proof this, but pretty sure it even works with a point in the center, and use a circle from slot end. IDK if they need to lie in same plane for the calculation.
I would try to create circle from end of curve of slot, then create theoretical point with coords to center point. Then construct tangent point<->circle from slot. Same for oposite side of same slot, then you can measure angle.
Theoretical point can be also recalled from element which defines center point.
There was a difference using the maximum point compared to the tangent point, I think the tangent point/line creation might be more accurate.
I got a difference of 0.3°... 28.7 with the max/min point for curve & 30.01 with the tangent line creation.
Nope.
Yep. You could use maximum/minimum point to greater accuracy if you created 15 degree alignments to match the basic angle and got the max/min from that.
